PI Cams in NPI Heads
Old 06-12-2007, 11:16 PM
karmstrong_2
karmstrong_2's Avatar
Default PI Cams in NPI Heads
I'm putting PI cams into my NPI heads on my 98 GT? I read something about needing a new PI cam gear bolt as mine didn't come with it. Is this true and if it is true where can I get it at? Thanks
karmstrong_2 is offline
Old 06-12-2007, 11:22 PM
lizzyfan
Underboss
lizzyfan's Avatar
Default RE: PI Cams in NPI Heads
All that work to do it, why not just the full PI head/intake swap?
lizzyfan is offline
Old 06-13-2007, 01:40 AM
karmstrong_2
I don't want to raise compression because I'm going supercharged down the road!
Old 06-13-2007, 01:47 AM
Jexey
Jexey's Avatar
get some blower cams yo
Jexey is offline
Old 06-13-2007, 02:33 AM
H0SS302
H0SS302's Avatar
ORIGINAL: karmstrong_2
you changing the heads to pi is going to be no different than us new edge people slapping a blower on.... ull have the same heads we do once u do it so why would it matter?
H0SS302 is offline
Old 06-13-2007, 03:31 AM
jst854
jst854's Avatar
becuase putting pi heads on a npi engine will raise the compression, not sure how much, but it does raise it to be higher than that of either stock pi or npi heads, you then face detenation when using fi
jst854 is offline
Old 06-13-2007, 03:34 AM
01GT4.6
01GT4.6's Avatar
thicker head gaskets will cure that.
ORIGINAL: jst854
01GT4.6 is offline
Old 06-13-2007, 11:34 AM
97stanger
97stanger's Avatar
Fredand me both have different opinions on this subject as well
He seems to have had 0 problems with increase in compression and boost, but then again he was only running 8 psi and is currently have a built shortblock put in. I think if the car is your DD, then i would stay away from the PI heads, just get your NON PIs ported and it will be the same gains with the same compression. I also agree that you should do some blower cams if you are eventually going to be doing a blower.
97stanger is offline
Old 06-13-2007, 06:51 PM
karmstrong_2
Thanks for the help guys and for the opinions but I still don't have any answer to my original question. I already have the PI cams but just haven't installed them yet and need to know if I need a different cam gear bolt.
Old 06-14-2007, 07:30 PM
droptoppony
droptoppony's Avatar
yes you need a PI cam gear bolt...buy it at Ford
droptoppony is offline
GimpyHSHS
19
12-19-2023 01:12 PM
kevsgt
10-09-2015 10:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
Drastang
09-30-2015 03:48 AM
Quick Reply: PI Cams in NPI Heads
