water pump pulley with procharger?
anyone know what the diameter of their stock water pump pulley is? I dont know if mine are after market or what but it is 6.5 inches and is in the way of me putting the dam procharger on there...
I need a water pump pulley that is like 5.5 or 6 inches in diameter.. any ideas
the belt touches its self inbetween the ATI idler and the water pump:
RE: water pump pulley with procharger?
ORIGINAL: sxynerd
Go to Advance Auto or a AutoZhoe and ask for a pulley. I think we sell them for about 30 bucks. (Advance)
I found a set a guy has laying around that he took off when he put his underdrives on.. I'm gonna just use them I suppose...
More than likely, if you have an underdrive waterpump pulley, the others are too. Check your crank pulley and alternator pulley. If you are not sure, post pics. In the pic you posted, I can see the alt pulley, and it looks bigger than stock, but hard to tell without seeing the entire pulley. I would also keep that area clean of dirt and oil so you have no belt slippage problems.
jwog666
12-27-2021 08:09 PM
alternator, bracket, crank, dam, f1r, ford, mustang, procharger, pulley, pully, pump, stock, underdrive, water, waterpump
