ABS light
ABS light
Im sure this has been addressed before in the past, and i did run a quick search, but they are all related to the TC light too.
anyway, last night as i was driving, my ABS light came on and stayed on for about a minute. it then went off. did the same thing again this morning. it never stays on, but it keeps comming on for a short period of time usually within the first 5 minutes of my car being on. last weekend i had the brakes repaced in the front and back, and i havent noticed anything but great performance from my system until this light thing started. Any ideas?
RE: ABS light
One of my tires rubbed through my back ABS wire. It would come on off and on when it first started. I didn't check on it till it stayed on and didnt go off. Lengethed the wire and added a zip tie and it was as good as new
RE: ABS light
or you can do what I did when my abs light stayed on, unplug the bulb. I didn't actually do it until i installed the Roush guage cluster and thought, hmmm, I should pull the bulb for the abs light so i don't have to look at it anymore.
RE: ABS light
ORIGINAL: sxynerd
Same exact thing happened to me. It started off going on for a few minutes and then eventually it just stayed on. I must have knocked the abs wire out of the little clip that holds it when I did my exhaust and the wire was rubbing against my rear rim and eventually wore through
RE: ABS light
Mine did the same thing. I still havent found the problem. The rear looks good, but i havent checked the front yet. like it was stated, the sensor is def a condition. I couldnt find any wires that were worn through, but i guess i will recheck. mine turns on about a minute after i start her up and stays on steady now for almost 9 months. hell when i hooked up the diagnostics it kept coming back with faults. its not even showing up on that. I dont want to spend the cash on the shop figuring it out. would rather put it towards a supercharger. the haynes doesnt really say anything about it either, which sucks.
jwog666
12-27-2021 08:09 PM
lincolnshibuya
12-08-2015 04:37 PM
