Forged Bottom
Old 07-31-2007, 11:29 AM
nanaki
Retired MF Moderator
nanaki's Avatar
Default RE: Forged Bottom
ORIGINAL: adam_ferguson
lol if your talking about 550 hp i'd be more worried about the transmission....
my stock transmission is holding up just fine with 547RWHP.
nanaki is offline
Old 07-31-2007, 12:06 PM
Matts00GT
Matts00GT's Avatar
I wouldnt worry about the crank. I'd worry about your transmission and rear end first.
Matts00GT is offline
Old 08-01-2007, 02:53 PM
ajmodelski
ajmodelski's Avatar
My goal is around 650 rwhp. I plan to do a turbo kit at around 15 psi. so I do want the crank. From what I have seen with all the other stuff you need to buy you are only saving a couple hundred bucks in the end. And considering the differance of possible power, I don't see why you wouldn't go for more. The differance of running <500hp and 500+ is a forged bottom end. So if you are going to forge part, why not go all the way. If your going to over 500hp, you should be running a trubo kit, do to efficiency and a list of other reasons. And the differance between 500 and 800 hp is injectors and a tune. So why wouldn't you just go all the way. Thats what I figure.
ajmodelski is offline
Old 08-01-2007, 03:14 PM
lizzyfan
Underboss
lizzyfan's Avatar
ORIGINAL: Matts00GT
+1, but you might as well do the crank!
lizzyfan is offline
Old 08-01-2007, 03:26 PM
sstang
sstang's Avatar
You plan on going turbo but still keep the cost down...? Not gonna happen. Building your own or buying a kit? You will be happier in the end if you forge the crank, plus you can rev higher.
What I would do is go forced induction first. Go ahead and safely max out the stock internals. Then save for a forged bottom. At least this way you will still be pretty fast.
sstang is offline
Old 08-01-2007, 03:59 PM
Matts00GT
Matts00GT's Avatar
ORIGINAL: ajmodelski
No offence dude, but I hear this "Im going for 650rwhp" all the time and most of the people havent even driven 400rwhp cars...If you are actually going to follow through with your goal then yeah, purchase a new crank for it. Dont get offended, but Ill believe it when I see it.
Old 08-01-2007, 05:22 PM
nathansee3
nathansee3's Avatar
IMO I would just buy a ful forged shortblock for 3G and call it a day. Get the forged everything and good till whatever limit u want to take it.
nathansee3 is offline
Old 08-02-2007, 09:01 PM
ajmodelski
ajmodelski's Avatar
I have not driven a 400whp car before. But I have driven a 350 whp subaru and I am on a hydroplane racing crew. I know how my mind works, and I know that when I have 400hp. I'm going to want 500 and when I have 500, I'm going to want 600. 650 is the peak I will allow my self. As for keeping the cast down by buying the kit now and forging the bottom later. Not worth it. I don't want to put all that **** on more than once. And a full forged assembly with berrings and everything is $1800. An easy cast compared to the $5000 for a trubo kit. I hope that when I install my mods up to the point when I want the Turbo kit, I'm happy with thepower output. But I know I wont be.
Old 08-02-2007, 09:16 PM
Twogunsblazin
Twogunsblazin's Avatar
ALL MOTOR FTW!!!! +1 on the believe it when i see it thing.
Twogunsblazin is offline
Old 08-03-2007, 06:29 AM
nanaki
nanaki's Avatar
i wouldn't even worry about 550HP if you don't plan on upgrading your fuel. you won't even get out of the 400s.
nanaki is offline
10-26-2015 05:01 PM
69MustangCoupe393cid
10-03-2015 10:33 AM
maestro1024
09-21-2015 02:40 PM
EASTIDEE123
09-14-2015 03:52 PM
rdog69t
SVT Forums
09-13-2015 06:16 PM
Quick Reply: Forged Bottom
