Tapping Noise?
Tapping Noise?
We just got done putting a fresh rebuilt motor in my 02. Everything is all fine and dandy until 4 days later and it starts to tap. It only taps when you start it and hit 3K rpms and sometimes I have to turn it over twice to start. We change the oil and the mechanics notice a lil silver coloration to it but they say that looks normal for breaking in a new motor. Then they suggest the flywheel maybe loose. I ask my cousin if he torqued it down and he said no he tightened tigth but not torqued. Could this be the problem?
RE: Tapping Noise?
So, it only taps when you very first start it and then it quites right? Can you get a short vid of it making this noise? If it makes like a rattling noise for just a few seconds upon startup then it's probably the main bearings.
RE: Tapping Noise?
I had the main bearings go out in my truck. When I started it after it had been sitting for several hours it would rattle for a few seconds kinda like all the rods were knocking then completely quite. If I shut it off for a little while and started it back up it didn't do it. I had to let it sit for several hours before it would do it again. It progressivly got worse and worse until it was knocking all the time. I hope that's not what's wrong with yours but I'd need a vid to get a better idea.
jwog666
12-27-2021 08:09 PM
KingRando
10-02-2015 08:06 AM
Ghost_Conscience
09-23-2015 02:17 PM
