wont start
RE: wont start
ORIGINAL: rob1210
well i checked the grounds everything is good any other ideas btw the theft does blink i dont remember if it did anyways
if it stays onblinking AFTER the key is &on, watch it it will blink a code.
it should turn off after you turn your key on
RE: wont start
i to recently had this same problem id turn the key and it did nothing but click then id hook up the jump box and it would start and run fine but as soon as i turned it off the problem was back it wouldnt start. so i unplugged the battery overnite and in the morning jumped it drove it to the dealer and they had it for 7 hours and couldnt find anything wrong with it they said it was fine, and evertime they turned the key it statred right up. and ive had no problem since then idk im still curious as to what it could be.
dalefrancis88
09-11-2015 07:15 AM
