? FOR THE SUSPENSION PROS! (UPDATED!)
RE: ? FOR THE SUSPENSION PROS!
lols everyone else pretty much got it, blown shocks/struts depending on how it was blown can definately cause your ride height to change on one side. The blown shock/struts will no longer compress or rebound so that may be causing the gangster lean ya have. I don't know if the eibachs can be attributed to the extreme difference but a combination of both could account for the big lean.
ORIGINAL: hot wheels
does nobody use the search function? those eibach prokit are notorious for an uneven drop.check the posts out, tons of complaints.
ORIGINAL: Aereon
Ok, changed rear shocks and only changed a 1/2" of difference on the rear. So, don't know about you all but new UPR tubular rear control arms are going on next week and hopefully that helps.
ORIGINAL: Romer
Are you the only owner of the car? Do you know the full history of it? Any chance it might have been in an accident?
Matt's 95 Stang
10-05-2015 07:16 AM
