Keyless Intry.
Old Apr 4, 2008 | 07:05 PM
jlg32281's Avatar
jlg32281
Default RE: Keyless Intry.
ORIGINAL: 1999 GT
save the frustration...take it to the dealership- thats what i did
You sir must have way too much money.
If the locks cycle when you connect the terminals in the trunk, that means it's in programming mode. The only reason it won't work is if the remote is broken, it's the wrong remote, or if the remote battery is dead. Depending on year model, you have to have different remotes. If you have a 98, then there are two possible remotes since they switched systems mid-way through the year. Get the right remote and it will work. Autozone sells them, but I'm not sure of the price. Ebay has everything.
Old Apr 4, 2008 | 07:17 PM
bjh061487's Avatar
bjh061487
if he has a different ford it prob won't work... i was just assuming that he had a mustang too and the year could also make a difference
go to ebay and look up the seller 'remotewholesale' (without the quotes) and put in 1998 Mustang into his store search and you will see plenty of remote key fobs for our mustangs and they are 25 bucks shipped and you will be set
Old Apr 4, 2008 | 07:31 PM
y2kStangGT's Avatar
y2kStangGT
programming is really easy.
you don't have to remove anything.
i have the instruction somewhere.
i'll find it for ya.
Old Apr 4, 2008 | 07:37 PM
y2kStangGT's Avatar
y2kStangGT
Here's the instructions.
1.Turn ignition from OFF to RUN 8 times within 10 seconds, with the 8th time ending in
RUN. Door locks will cycle to confirm programming mode.
2. Within 20 seconds press any button on first keyless remote. Door locks will cycle
to confirm programming.
3. Within 20 seconds, press any button on second keyless remote. Door locks will
cycle again to confirm programming.
4. Turn ignition to OFF. Locks will again cycle to indicate end of programming mode.
If you are only programming 1 remote you can skip step 3.
Old Apr 4, 2008 | 07:42 PM
y2kStangGT's Avatar
y2kStangGT
For New Edge you can use any remote that has an ID of CWTWB1U322 or CWTWB1U331.
I bought my remotes on ebay and programmed them myself.
It only took 2 minutes.
If you ever need to program your remote for any other cars. Check out this site.
http://www.programyourremote.com/
Old Apr 4, 2008 | 07:44 PM
y2kStangGT's Avatar
y2kStangGT
if you want to program your key then you would have to bring it to the dealer or Home Depot.
Home Depot is 1/2 the price.
Old Apr 16, 2008 | 07:03 PM
Knight_Rider's Avatar
Knight_Rider
Hold On Thar!!! -- Different remotes?? Okay!!, Thanks Ford!!
Have the remote off Fleabay with the code "CWTWB1U322" bought "working" but who knows!! Module is not visible ANYWHERE in the trunk cavity!! Am I missing the part?? Has the PATS key that seems to work fine, turn off the engine, pull key, something beeps 4 or 5 times.
Is there a way to verify the code using the VIN??
Any Ideas out here??
Old Apr 23, 2010 | 04:46 PM
etsuHoopsFan's Avatar
etsuHoopsFan
This procedure will not work for a '98. You have to short out the plug as others have noted. For those, like me, that had no what this plug looked like I have attached pics. Simply put a screwdriver in there and you will hear the door locks cycle. Then follow directions as others have posted. Worked for my 98.
97Cobra
Nov 17, 2006 10:01 AM
Hambone
Aug 16, 2005 01:01 PM
Richman
Jun 5, 2005 09:49 PM
ss4ever
May 17, 2005 11:03 AM
sykopafikjuggla
Jan 20, 2005 03:47 PM
