running lean??
Old Jun 16, 2008 | 02:33 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
Default RE: running lean??
2003 was 5 years agohoweverthatreally doesn't means anything, how many miles on the car?[/align][/align]The Fuego is not a bad tuner; I had one, my brother uses it now on his '99 GT. [/align][/align]It is howevergrossly misrepresented by Granatelli and that pompous *** that runs it, "JR". It does not do data logging, does not have any PC interface software, and obviously because of that does not have "Tunes available over the internet". But, it is not a bad tuner...[/align][/align]Back to the main issue, what were the specific codes returned when the SES light was on? What selections did you make when you created the Fuego tune, I haven't used it for a while however a few "memory jogs" might let me help.[/align][/align]And by all means check for leaks, there's nothing about the rear O2 sensors that would cause the engine to run lean, or the PCM to think it's running lean. They are only used to monitor the cats.[/align][/align][/align][/align][/align][/align]
Old Jun 16, 2008 | 02:49 PM
GodAmGT00's Avatar
GodAmGT00
Isn't Bank 2 a front O2 sensor??
JT
Old Jun 16, 2008 | 02:58 PM
cliffyk's Avatar
cliffyk
TECH SAVANT
ORIGINAL: GodAmGT00
JT
[/align][/align]Bank 2 is the driver's side. bank 1 is the passenger's side. Sensor 1 is front, sensor 2 is rear...[/align][/align][/align][/align]
Old Jun 16, 2008 | 03:39 PM
2003gtstang's Avatar
2003gtstang
Ok i just went unedr the car while it was running and noticed that the (drivers side) X pipe is leaking where it is bolted to the manifold. I think this may be the problem, as long as bank 2 is the drivers side
Old Jun 16, 2008 | 03:54 PM
oxfordgt's Avatar
oxfordgt
Yes bank 2 is driver side. All ford engines bank 1 is the side with cylinder #1 which on our motors is passenger side.
Jb145700
Aug 21, 2022 06:37 AM
Oct 7, 2015 07:02 PM
heslekrants
Sep 23, 2015 04:02 PM
TorinoCobra070
SVT Forums
Sep 18, 2015 10:34 AM
uedlose
Sep 10, 2015 03:30 PM
