2v to 4v heads
Its gonna be more than you want to do, it would be easier (maybe cheaper) to buy a 4v motor, harness, and ECU. You can google it and it will more than likely bring up some results from this site.
ORIGINAL: mustangcat
Yeah.
The 4v Heads won't properly fit a 2v cylinder block(which is too small I believe). Your better off buying a 4v Motor like 35th said.
Yeah.
THE HEADS DO FIT ON THE BLOCK!!. The engine will be low compression though. You need fuel rails,injectors ,wiring ,ecu ,mass air ,2 secondary timing chains ,2 secondary cam gears 2 secondary timing chain tensioners, 32 valves ,32 springs ,32 retainers 64 keepers the intake manifolds, and throttle cable thats all I can think of off the top of my head.
