Ok here is whatI just figured out. 3 corners will line up perfectly. The inside of thehead(other side ofexhaust ports)is dead straight and so is the back side. Its just the front corner that is off by about 1/8 inches. Anythoughts on that?
Ok... so here was the deal. The exhaust header was hitting the end of the bolt on the 7th cylinders exhaust tube. I just had to convince the tube to bend in some with a hammer and everything fell right where it should be. Thanks for the infomation though.
