Meziere electic water pump?
I made a thread about the meziere electric pump and I got replies from people who have been usnig it for years without any problems. The only problem I heard was that you can be using a crappy relay which can burn out thus causing the pump to fail. If you use a quality relay, then it should be fine.
There was also an article about the meziere electric pumps being put on a Z06 and what are the advantages of doing so apart from the obviously HP and TQ gain. One was that because it will flow the coolant at a constant rate, and not proportional to the engine RPM's, it will therefore cause the coolant to be more efficient.
Other people have said they received partial shipments and had to wait months for the rest of the kit. RPMOutlet's policy states that there is a fee if you cancel an item that is backordered. You need to read their terms and conditions carefully.
If you have had good service from RPMOutlet then you have been lucky.
^ i got sent two of the same thing when i called they said send one back and they will send the right part... i called back 2 weeks later... it was on backorder for 3 months... they finally refunded my money 4 months later... (i think i got my $ back...) i was ordering alot of stuff at the time so im really not even sure if i got my money back.
jwog666
Dec 27, 2021 08:09 PM
