Steeda U/D Pullies
#41
Yes, but I wouldn't recommend it. Compatible, but not safe. Since the UDPs change out the crank pulley, the timing will be slightly different and possibly affect the application of the Nitrous.
Personally, I wouldn't add Nitrous to a street car because too many things can go wrong with it and cause problems.
#43
You have it right. If you do LTs, the headers have to be removed (or at least loosened) for any clutch/flywheel/tranny work (I found that out the hard way =\.) Looks like you already have wheels/tires? Headers and install definitely aren't cheap, but doing the clutch and flywheel at the same time is definitely a good idea.
Yeah I'm not trying to double pay for labor, so I am thining next spring or summer I will try and get that stuff done. I've got a lot going on this year (ending deployment, moving from Germany to NC, getting married and moving my lad out to NC) and need wheels/tires (mine are stock still) more than I need headers and a clutch/flywheel. Car only has 25k on it so the clutch should easily last until I want to do the headers. Then next deployment, it is time for suspension.
I also wouldnt reccomend N2O on a street car, mainly b/c I've heard too many horror stories
mungodrums
09-28-2015 10:54 PM
09-24-2015 09:18 PM
09-16-2015 07:53 PM
