Whitish-grey thick smoke coming from tail pipes.
Old 06-14-2005, 10:01 PM
Blown00GT
Blown00GT's Avatar
Default Whitish-grey thick smoke coming from tail pipes.
hey all, i got another problem. now i have this whitish- greyish coloroed thick smoke comin from the exhaust pipes. i heard that light colored smoke is never good so i wanna know what it could be? a mechanic said it could be oil in the engine. is that the headgaskets having a leak in them. i need only serious inquiries from people that have had this happen to them personally or someone else. the reason is that im going on a road trip from virginia to michigan on military orders. thanks
Blown00GT is offline
Old 06-14-2005, 10:55 PM
ironh19
ironh19's Avatar
Default RE: Whitish-grey thick smoke coming from tail pipes.
head gasket or cracked head.
ironh19 is offline
Old 06-14-2005, 10:59 PM
01roushnj
01roushnj's Avatar
unplug the MAF sensor and start the car up. If the smoke still appears its probably your head gasket.
01roushnj is offline
Old 06-14-2005, 11:44 PM
Jglisson
Jglisson's Avatar
It won't run with the MAF unplugged.
Run a coolant pressure test. More then likely a headgasket, especially if you are running boost.
Jglisson is offline
Old 06-15-2005, 05:58 PM
pichinco
pichinco's Avatar
ORIGINAL: Jglisson
Wrong. It runs on the default settings in the computer rather than the readings in the MAF. It goes into what some folks call "limp home" mode. Losing your MAF won't leave you stranded. I've ran mine with the MAF disconnected before. Runs weird at times, but it definitely runs...downshifts are fun.
Light/greyish smoke definitely sounds like water getting into the engine. a.k.a. head gaseket or cracked head. Does it idle rough? Smell your exhaust, does it smell of antifreeze? Check your oil, if you see any "froth" or white foam it means water in the oil. Jglisson has a good point though, a compression check will definitely let you know. You can pick up a gauge at a parts store for a little of nothing. Hose with a screw-in fitting to go into the spark plug hole. Tedious, but not hard to do. Will generally expose a blown/leaking head gasket pretty quick.
pichinco is offline
Tivo304
08-28-2023 12:19 PM
fastbackford351
09-12-2015 09:42 AM
uedlose
09-10-2015 03:30 PM
tmdm
09-04-2015 06:45 PM
amandahchase
09-03-2015 10:09 AM
Quick Reply: Whitish-grey thick smoke coming from tail pipes.
