99-04 auto to 5 speed swap wiring questions
Old 07-17-2009, 04:34 PM
jedquist
jedquist's Avatar
Default 99-04 auto to 5 speed swap wiring questions
does anyone have a good how to or a write up on what exactly needs to be done when swapping an auto , to 5 speed(t45) without getting the harness. i know it can be done but i cant seem to find anything concrete or for the right year car. i just need the wiring how to, everything else is pretty straight forward.
jedquist is offline
Old 07-17-2009, 08:01 PM
Jazzer The Cat
Retired Moderator
Jazzer The Cat's Avatar
From the FWIW Dept., I will pass on my link to a T-3650 to T-56 swap thread
I am not sure how much good it will do you, but there it is.
Jazzer
Jazzer The Cat is offline
Old 07-17-2009, 08:33 PM
Sxynerd
Sxynerd's Avatar
Keep the Auto and just make more power.
Sxynerd is offline
Old 07-17-2009, 11:12 PM
Frostbitten
Frostbitten's Avatar
you need the harness. they can be found for pretty cheap
Frostbitten is offline
Old 07-17-2009, 11:35 PM
zero2005
zero2005's Avatar
i would stick with the auto, i love manuals, but auto is so much more easy, and from what i gather a shift kit + stall + big gears = sex.
zero2005 is offline
Old 07-18-2009, 06:20 AM
Jazzer The Cat
Retired Moderator
Sports car with automatic trans = traveling
Sports car with manual trans = driving
Jazzer on A to B
Old 07-18-2009, 01:08 PM
jedquist
jedquist's Avatar
i already have everything(minus the trans harness) for the 5 speed swap. the 4r70w is shifting like **** so im swaping cause i need it not just cause i want it. also total for the swap with a used t45 cost me $600!!! can even come close to any sort of performance auto for twice as much... and by the way the only used parts are the trans(out of a friends car) and ebay pedal assembly everything else is new, so the t45 should bide me time to save for the tko! plus manuals are just so much fun.
jedquist is offline
Old 07-18-2009, 04:13 PM
zero2005
zero2005's Avatar
ah didnt know you already had all the parts and the auto was takin a **** on you. if thats the case then by all means go for it.
zero2005 is offline
Old 07-19-2009, 07:07 PM
J_Rod
J_Rod's Avatar
its cake you can use the auto wiring harness, thats what i did when i did my swap
J_Rod is offline
Old 07-19-2009, 07:08 PM
J_Rod
J_Rod's Avatar
get a haynes manual i know there junk but the wiring diagrams are accurate, you can study it like i did and you can tell really quick what wires need to be spliced together etc. its very easy
J_Rod is offline
Cannibal_carnies
03-02-2023 06:17 PM
jpplaw
08-22-2015 09:29 PM
Stilz
08-18-2015 09:40 AM
StangMuscle
08-12-2015 07:27 AM
Mignav001
08-11-2015 02:28 PM
Quick Reply: 99-04 auto to 5 speed swap wiring questions
