Smelly!!!
Smelly!!!
About three days ago I noticed a stench in my car(Almost smells like feet). I coulndn't figure out where it was coming from. The smell worsend over a few more days. Turns out its coming from my vents. I was wondering if this could be a heater problem or somthing like that.
Thanks...
Thanks...
RE: Smelly!!!
better hope its not your heater core! Could be sending antifreeze into your vents which would start to mildew. If your not careful, you could overheat due to insufficient antifreeze and end up cracking your heads. Have it checked by a professional.
RE: Smelly!!!
umm yeah you should bipass it like i did, just disconnect the heater core and reconnect your coolant system to itself. cracked heater core with coolant flowing through it = coolant all under your carpet not to mention constant low colant light!. check your carpet on the passenger side closet to the dash. if it smells like maple syrup, then you got coolant leaking from your heater core.
Runningoutofcreativenames
03-03-2013 03:43 PM
