Air/Fuel Ratio
#21
RE: Air/Fuel Ratio
I was running on a DynoJet, the temp was over 90 F, I understand the heat takes away from power, but the fact is my A/F is running very rich, from what I understand the more Air you flow the leaner my ratio should get, is this wrong?
#22
RE: Air/Fuel Ratio
Here's a couple Bullitt dyno runs
http://www.stangnet.com/pbullitt/bullittdyno.html
http://www.musclemustangfastfords.co...111mmf_bullit/
#23
RE: Air/Fuel Ratio
ORIGINAL: BlueBullitt
#24
RE: Air/Fuel Ratio
So here's the question... Can he reset his EEC by disconnecting the battery for a while and expect the A/F ratios to even out while the EEC relearns the maps, or does the EEC need to be completely re-tuned? If it must be re-tuned, can this be done by a simple "flash" at the dealership, or is it necessary to puchase a chip/tuning device?
uberstang1
09-20-2015 06:42 PM
09-03-2015 07:14 PM
