4.6 heads on a 5.4???????
Does anybody know if I could put DOHC 4.6 heads on a 5.4 block? I am pretty sure that the two engines are the same size in dimensions, but I dont know if they would actually bolt up.I was thinking of getting a Navigator DOHC 5.4, but that has a iron block. I want to take a SOHC aluminum 5.4 and place the 4.6 heads on it. I want to do this because the 4.6 DOHC engines are far more common than the 5.4.
Thanks alot guys! I thought it would, but I wanted a second opinion before I spent any money. Now I need an aluminum 5.4 f-150 block and a Lincolin heads. Then I go real FAST!<IMG height=17 src=smileys/smiley4.gif width=15 border="0">
Originally Posted by Jugador
then why cant the DOHC 4.6heads go on a SOHC 4.6
They can, you just have to add other parts like a different front cover, probably crank gear etc....</P>
