What MAF to use
What MAF to use
Talked to my local tuner a few days ago about getting my car tuned there once (or if) the S/C ever gets installed. He mentioned that he refuses to tune a Lighting MAF in a blow-through configuration, and said to check out a P-MAF unit.
I am leaning towards either a 85mm unit:
http://www.promracing.com/mass-air-m...um-flanged-p-7
or the 3" pro tube:
http://www.promracing.com/mass-air-m...3-pro-tube-p-9
Anybody have any experience with either of these? I am kind of leaning towards the 3" tube, as it looks cleaner (even though you will not see it)
I have a P1SC kit intercooled, and as I live in CA. and I have to pass Smog, I am essentially gonna leave the rest of the engine stock. (I also want to keep the HP levels under 400hp, so I do not push the motor to the brink)
or the 3" pro tube:
I have only a single comment, no recommendation as to which of the two (see below).
* - 3" is 76.2 mm, smaller than the stock MAF, while this is not a huge factor in a blow-through application you may wish to consider it;
Back to recommendations, I have none because it really doesn't matter as long as you have; a) a MAF that can meter the maximum amount of air your engine can ingest without pegging, and b) as long as you have a 30-point MAF transfer function for the selected MAF.
If both a and b are true than the MAF will work and any competent tuner will be able to create a tune that will work with it. What ever you do DO NOT get a "calibrated" MAF as it will make your tuner crazy--make it clear to whomever you buy the MAF from that you are going to have a custom tune built to it's transfer curve.
Click here for more about Why Calibrated MAFs Suck...
jwog666
12-27-2021 08:09 PM
stangin1996gt
09-21-2015 11:01 AM
