Loss of back pressure?
So I currently am running a muffler delete on my mustang. Im looking to dropping 2 cats on either side though so there is only one on each pipe. Now can anyone debunk the rumor that this is actually bad for your car since it will be eliminating back pressure? or is it actually not a good thing
http://www.moddedmustangs.com/forums...-cut-outs.html
#16 is important on this thread http://www.moddedmustangs.com/forums...-cut-outs.html
And i know you didnt say cutouts but you asked about "backpressure" and the str8 through exhaust.
Those links explain it perfectly. It is the velocity and not the back pressure. If you use anything over 2.5 inch diameter with these engines I am told it is a very noticeable drop in power. That is part of the reason x-pipes work so well also. The pulses are synchronized and help keep velocity up. Long Tube headers also have an impact in particular on low end torque but are great for high RPMs.
This issue has been tossed around since I was child in the 70's and probably even before that. My father explained it to me as I looked at the somewhat smallish pipes on his 4 wheel drive in comparison to the functional "sidepipes" (LOL) on his 69 Corvette. If I was the OP, I would be dropping cats and running mufflers with X or H pipe of near factory size. It has been proven effective for years.
CMcNam
10-30-2022 11:40 PM
musnicki
09-23-2015 07:11 AM
