Snap!!!!!!!!
Old Sep 18, 2005 | 06:48 AM
Whitestang04's Avatar
Whitestang04
Default Snap!!!!!!!!
Tonight was gonna be the last time I run my car till the weather warms back up after winter. Well,I was sitting on the line waiting on the light to drop when all of a sudden I dump the clutch and snap[:@]. That was the only sound out of my rear end. I think I might have just got a axle(which sucks but made me proud) I am gonna go a take it apart and check it out tomarrow and see. So here is my ? does anyone know the average price for a axle and exactly what kind of axle is in my car. Plus what kind of axle should i replace it with to strengthen the rear end. Thanks
Old Sep 18, 2005 | 01:56 PM
DuckyGt's Avatar
DuckyGt
Default RE: Snap!!!!!!!!
a 31 spline axle and should run you $200-300 i believe.
Old Sep 18, 2005 | 02:54 PM
blueangelfightr's Avatar
blueangelfightr
I think he's right.
Why would you put it away already? It's way to early, wait till like Nov. Your car loves cool air.
Old Sep 18, 2005 | 07:02 PM
sk8erdudex's Avatar
sk8erdudex
Yeah I had an accident with my axle once. But it wasn't because how cool my car is lol. I hit a curb while drifting. The whole operation was $700 the axle I believe was $210
Old Sep 18, 2005 | 11:13 PM
jdaniel's Avatar
jdaniel
I ♥ Acer
You can get a set of 31 spline axles for about $250, the diff for about $350 and have it all installed. I bet it was the spider gears that went out. Ive never heard of 28 splines going out without a power adder of some sort. I used to do 5000 rpm launches on 275/60/15 BFG's and never broke traction and I never even bent an axle.
Old Sep 19, 2005 | 01:21 AM
Whitestang04
ORIGINAL: blueangelfightr
I think he's right.
Well its only a few weeks till bow season opens for hunting so thats my hobby for the winter.
Well i took it all out and its definatly a axle, driver side.My ring and pinon and spider gears all look fine. The teeth are still all there. But it broke off right at the end of the spline on the end of my axle and flared out so we couldnt get it down far enough to get the c clip off to take the Broke piece out. So im going tomarrow to try and get it pressed out. Hopefully my diff is still good im not sure because of where it broke at though. The sad thing is i cant find anyone that can get me a axle. Im not sure but i heard the only one that would fit it is a 99-04. The only help i got was to call the ford dealer and i am tring to stay away from them if anyway possible. ( I dont have a extra arm and leg to give right now)Is there any place to go on the internet to buy a axle for my car and it is a 28 spline correct. Thanks for you help.
Old Sep 19, 2005 | 02:17 AM
Whitestang04
is my car a 28 or 31 spline
Old Sep 19, 2005 | 12:11 PM
Fishhawk's Avatar
Fishhawk
ORIGINAL: Whitestang04
I believe you have 31 spline. You also might be better off with just buying a new pair of hardened axles. I've had good luck with Superior. A lot of guys use Mosier or Strange. Summit sells a set of Superior hardened axles for your car. Their part number is SAG-EV84. $249.99. They come with bearings.
http://store.summitracing.com/defaul...=egnsearch.asp
Old Sep 19, 2005 | 09:37 PM
duece1019's Avatar
duece1019
you should have 28 spline axles if your rearend is stock.
Old Sep 20, 2005 | 04:24 AM
DILO2001GT's Avatar
DILO2001GT
I ♥ Acer
you have 28 if you want 31 i think you need to change your differential but im not sure so don't take my word for it
bjdutch2005
Mar 24, 2017 03:38 AM
JDWalton
Sep 24, 2015 08:47 PM
yurizx6r
Aug 24, 2015 05:48 AM
ponyride00
Aug 12, 2015 01:57 PM
SilverBullet5.0
May 18, 2004 01:31 AM
