Couple issues need some guidance
@ OP, if you have had both control arm bushings replaced on both sides then a cracked spring is all I could see it being.
I've seen this before. Check and see if you still have dust covers on your struts. If not, THAT is likely to be the issue. The dust covers have the metal disk that the strut seats into, and the dust cover seats into the upper cup. It is necessary unless you have coilovers.
When I did my first set of struts, I left the boots off and the strut rods made contact with my hood. They are not easy to find on ebay, so junk yard or Ford. Takes some time to put them in, but not hard really. Undo the sway bar end links, the top nut on the strut, and lower the arm with a floor jack until you can compress the strut enough to swing it out and slide the boot on.
IF I'm correct, your car will behave utterly differently.
If he just had the control arm bushings replaced, you would think the shop would have told him about the spring....must be one hell of a shop.
Dragonus18
09-09-2015 01:21 AM
