Putting on Edelbrock Victor JR intake W/ Throttle Body
I recently decided to put on the new version Edelbrock Victor Jr Intake Manifold W/ Throttle body for my 03 Ford Mustang GT. .....have main parts..intake,fuel rails,75mm accufab throttle body.....Its Obvious that this swap out will require some technical know how as that some of the current stock parts will not be able to stay....et al..fuel rail pressure sensor....this manifold requires special fuel rails that do not have a place for the pressure sensor to go on to the rail itself....
I have done some mods already: Cams,Cold air induction,Tuned,Gears (3.73)
I am looking for all the help and info if anyone has done this type of swap out
I don't know anything about the power increases so I can't speak to that but as far as parts swapping goes intake manifolds are pretty simple. You're stock fuel rail should be held on by two bolts remove those and wiggle it loose being careful not to lose injector o-rings. The intake itself is unbolt and remove. Make sure to tighten the new one in a cross pattern a bit at a time to ensure a good seal. As far as the sensor goes can you mount it or another one in line before the fuel rail? Since you have to replace it might I also suggest removing the intake with the fuel rail attached so if you do drop an O-ring it doesn't end up in the head. Be advised you're gonna spill some gas.
JDWalton
09-24-2015 08:47 PM
