98 mustang gt injectors not working (LH)
Old 02-03-2013, 02:04 PM
Synyster
Synyster's Avatar
Default 98 mustang gt injectors not working (LH)
I have narrowed down my problem and apparently it is this. I know Spark is going into the cylinders but Injectors 2-4-7-8 are not spraying. Anyone know why it's not? Help is always appreciated.
Synyster is offline
Old 02-03-2013, 04:59 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Injectors 2 and 4 are on bank 1, passenger side; 7 and 8 are on bank 2, drivers side:
All injectors receive +12 V via the same fuse, fuse #2 (20A) in the central junction box, and are operated by the PCM switching them to ground via MOSFETs. After the fuse the harness splits to power the bank 1 (cyls 1, 2, 3, 4) and bank 2 (cyls 5, 6, 7, 8). The "ground" side of the injector connections are all "home run" lines straight back to the PCM...
Are you certain it is the injectors you list, and not one entire bank?
cliffyk is offline
Old 02-03-2013, 08:26 PM
petrock
petrock's Avatar
Rent a noid light kit from your local auto parts store and make sure that the injectors are being commanded on. If they are not then its an electrical problem. If they are then it is either a fuel injector problem or a fuel rail problem. I doubt its the injectors because all of them wouldn’t cut out at once. But that bank’s fuel rail could be restricted somehow not allowing fuel to the injectors.
Good luck...
petrock is offline
Old 02-09-2015, 09:46 PM
ethon
ethon's Avatar
Default Help
[QUOTE=Synyster;8145989]I have narrowed down my problem and apparently it is this. I know Spark is going into the cylinders but Injectors 2-4-7-8 are not spraying. Anyone know why it's not? Help is always appreciated.
im having the very same problem with my gt. Did u ever find out what it was?
ethon is offline
Old 02-11-2015, 06:04 PM
WJL
WJL's Avatar
How do you know they are not "spraying" ?
WJL is offline
mstahoo
SVT Forums
08-19-2021 09:15 PM
msavoia23
12
07-07-2018 12:08 PM
Soldier GT
08-12-2015 03:46 PM
daytooday
08-11-2015 09:22 AM
Redneck1465
08-08-2015 10:39 PM
Quick Reply: 98 mustang gt injectors not working (LH)
