Lighten Sn95
Old Oct 4, 2005 | 03:13 AM
96_cobra's Avatar
96_cobra
Default RE: Lighten Sn95
Thanks for the posts there were a couple of things i didnt think of. The car will be on the street but i am still concidering ditch the actual bumper still.
Old Oct 4, 2005 | 08:42 AM
Soaring's Avatar
Soaring
I ♥ Acer
ORIGINAL: David_K
get a fiberglass hard top and ditch all the convertable ****. like the motor and all the brackets and the tarp and you should be about the same weight maybe a little more than a coupe
Hey David, have you heard about the Yellow Mustang Registry?
http://www.yellowmustangregistry.com/
Old Dec 9, 2018 | 10:16 PM
Cobracary's Avatar
Cobracary
If you remove the power steering will it work well enough for road racing and I gues just plug the rack in and out fittings right?
Old Dec 10, 2018 | 10:14 AM
Buck Sergeant's Avatar
Buck Sergeant
WOW, I am glad to see so much enthusiasm about shedding weight. Every race car I have built has always been from the platform of weight reduction. Remember "Weight to Power" ratio? All suggestions are valid. Some a little scary, but valid. I have also gone as far as removing all unnecessary wiring. Do you know how much wire weighs. But, Soaring and David_K are right, a BIG item to remove, since it is a convertible, is the motor and all the hardware that goes along with raising and lowering. Yes, you will have to secure the convertible top in the raised position, but for weight savings this is another item to assault. Remember, light is fast.
Spring00gt
21
Nov 9, 2007 09:16 PM
scsi
Oct 8, 2006 07:53 PM
Katzilla87
Feb 9, 2006 11:41 PM
Dan04COBRA
May 1, 2005 06:43 PM
Ezrider
Mar 19, 2005 12:55 AM
