03 GT cruise control module broken?
Old 06-11-2016, 10:31 AM
usaf1965
usaf1965's Avatar
Default 03 GT cruise control module broken?
When I start to stop my car will stick at 1500 rpm and if I stop completely it will die. If I let off the brake the car will gain speed and change gears by itself. Any help???? I dont use the cruise control but I dont know what else it could be
usaf1965 is offline
Old 06-11-2016, 04:24 PM
jwog666
jwog666's Avatar
check the throttle linkage, and cruise linkage for binding and damage. the cruise will not do this by itself, there is a physical problem that should be very obvious if inspected.
jwog666 is offline
Old 06-11-2016, 05:12 PM
dawson1112
dawson1112's Avatar
Your cruise cable is not adjusted properly, let some slack out of it.
dawson1112 is offline
Old 06-11-2016, 07:54 PM
usaf1965
usaf1965's Avatar
There was a vaccum leak which i fixed. Im going to try letting some slack out. do you guys know roughly where its located??
usaf1965 is offline
Old 06-12-2016, 03:31 AM
09GT/CS
09GT/CS's Avatar
I haven't been under the hood of a 03 that had cruise but on the older fords it's typically a second throttle cable that routes to a box on the fender somewhere. You should be able to trace it from the throttle body one cable will got to firewall for the pedal the other will be the cruise control.
09GT/CS is offline
Old 06-12-2016, 07:25 AM
jwog666
jwog666's Avatar
the cruise on your year mustang has nothing to do with vacuum, however a vacuum leak can sometimes cause a high idle condition. do not try to adjust the cable unless you know FOR SURE that the cable is physically holding the throttle open at all times
jwog666 is offline
Old 06-12-2016, 11:26 AM
usaf1965
usaf1965's Avatar
Is there a module?? Am I able to disconnect it? and leave it disconnectede? cause the cable looks fine
usaf1965 is offline
Old 06-12-2016, 02:34 PM
usaf1965
usaf1965's Avatar
Everything looks fine , theres no module I figured out lol. Time to take it to Ford):
usaf1965 is offline
cobra40813
05-11-2016 12:10 AM
Urambo Tauro
05-09-2016 09:14 PM
BigSkoop
04-26-2016 12:49 PM
jgordon
04-10-2016 07:10 PM
Dan Moldovan
04-06-2016 09:40 AM
Quick Reply: 03 GT cruise control module broken?
