Transmission help, replaced clutch, no gears
Hows it going? I’ve run into a slight problem after installing a new clutch in a T45. After I bolted everything back up and was backing out my mustang when it wouldn’t go into 1st, you could shift it into 1st but it would stay in reverse. I let the car stall out gently and turned it back over and guess what? I had no gears. I installed the clutch correctly, everything mated up fine and everything is tourqued down to spec. Could it be an internal issue with the trans? Because it was pretty hard to get into gear before the new clutch, like you’d have to fight it sometimes. Or do I just need to bleed the system / adjust the cable?
