Transmission issues
Old May 2, 2021 | 09:36 AM
Drummer630's Avatar
Drummer630
Default Transmission issues
Hi, I recently had pulled my motor and tranny from my car to fix some strut rust. Along with fixing the rust I did some maintenance on the motor and tranny. I needed to put in a new power steering pump and I changed several fluids including power steering, oil, brake, and dropped the transmission pan to change that fluid and filter. I did not empty the converter. I also swapped out both u joints. Everything went good and I was ready to reinstall transmission and motor. Everything during reinstall seemed to go good as well but upon initial start up I received a flashing o/d off light and was given three touble codes. P07043, P0750, P0755. Everything was good before I had taken the motor out but I had to fix the rust and I figured why not do some maintenance. Has anyone had experience or similar instances that could possibly be of help to me.
Old May 11, 2021 | 01:25 PM
Derf00's Avatar
Derf00
Gentleman's Relish
What kind of fluid did you put back into the transmission? Hopefully not a universal tranny fluid...
If you removed the engine and tranny, and these codes appear to be electrical in nature, start by reviewing/tracing wire harness that goes from the transmission to the PCM/ECM. Check for kinked, broken, or pinched wires.
if that all looks fine the solenoid wires or solenoids themselves may need review/repair/replacement.
Old May 11, 2021 | 01:29 PM
Drummer630's Avatar
Drummer630
Thanks. I found it the other day after searching. Apparently the internal wiring harness came unplugged all's good for now. And I used mercon v of course
Old May 12, 2021 | 01:09 PM
Derf00's Avatar
Derf00
Gentleman's Relish
Glad it was a simple fix.
2012White5.0
Apr 24, 2011 10:44 PM
jimjeffords
SVT Forums
13
Jan 7, 2010 10:18 AM
dv3
Dec 4, 2008 09:20 PM
hellion_79
4 Cylinder NA and Turbo
25
Sep 28, 2007 01:26 PM
masterblaster
Jan 21, 2007 07:27 PM
