injector install & fuel pump
RE: injector install & fuel pump
but wouldnt the computer tell it how much fuel not the injector..I thought the injector just was their when needed but the computer told it when to flow more fuel
ORIGINAL: GT35thconvertable
I am guessing you have a 35th [8D] so installing the pump will be fine because it is a return style system.
The injectors would be a bad idea until the blower because of the state calibration issue.
Changing the injectors at teh time of the blower won't take more then a 1/2 hour longer. You'll just have to depressurize the rails remove the old injectors and install new ones and install the fuel rails. Not overly hard.
I would how ever recommend a pressure requlator in the mix to monitor the system.
There is no aftermarket fuel regulator for 99-04 it will need to be controlled by a chip/tune. And is the 255 for a returnless fuel system? If not, it won't last very long.
Sorry I meant sensor not regulator
http://216.242.145.16/products/product.phtml?p=100
My math was bad to 98 was the last year for a return system.
I would don't either now just do it with the blower install.
No the 42# injectors will not work unless the computer is reprogrammed. Even with a MAS that is calibrated for 42#. It will run but very bad. I know this because I put my stock tune in one time because my Predator crashed out on the road. Had to drive the car home and barely made it. When I first put my blower on I got a temperary tune so I could drive it to the dyno. If you have a SCT xcal-2 you can plug in the MAS and injectors right off the bat and it will run fine but don't get on it untill it's tuned.
Design1795
01-24-2017 10:38 PM
kawiguy827
09-01-2015 07:09 PM
