bolt on or s/c.....?
#21
RE: bolt on or s/c.....?
ORIGINAL: Hoppers01Gt
I have a question for you Code: Cams and gears will prob run mine close to a grand and spray will prob go for somewhere around $700. My question is what should I go with first, whats your opinion? The other night I go run all over by a Sti, and I dont want that to happen again. Thanks for any advice!
#22
I would do supercharger, your not going to make the same amount of hp and tq with full bolt ons. But you can always go full bolt ons, then forge the bottom and and you will be making all the power you will need. Nitrous is apealing sometimes, but I would like to have that power all the time, not just once in a while.
Cams, springs, valve spring compression tool, misc. cost me about $1000.
Gears, shims and bearings, gear oil, install. Cost me about $600
maestro1024
09-21-2015 02:40 PM
