quick unanswered question about gears
RE: quick unanswered question about gears
at higher speeds you will GAIN acceleration more then lose it. Your in a higher RPM range at the same MPH, so your starting closer to your max HP in your power band. The only thing gears cut down is top end and you really "shouldnt" notice that
What he just said. My fifth gear was a dog even with 3.55's, because Ford used a Tremec 3650 with a OD ratio of 0.62 instead of the the 0.68 used in '03 GT models. Now all is good....
With the 4.30's in my 02 GT, 5th gear felt like 4,500rpms in 4th gear felt like in my buddies stock 04 GT (the power that is...)
You won't need to down shift anymore to pass anyone, you can just ease into the gas and she will take off...
Luke9222
10-22-2015 11:55 PM
