Banshee Shaker and MAF
Old 01-27-2004, 01:41 AM
Marc_03GT
Marc_03GT's Avatar
Default Banshee Shaker and MAF
Ok..I think I know what I want but I'm not sure if it can be done. I want to put the Banshee Ram Jet hood and shaker on my 03 GT coupe with a C&amp;L 85mm MAF w/TrueFlow inlet pipe. I think I'm gonna put the 75mm Accufab TB and C&amp;L Plenum on there too. Think I'm gonna do it all at once. My question is can I use the Banshee shaker with the MAF from C&amp;L? Is 85mm over kill...I mean is it any better than 75mm since the TB and plenum are just 75mm? HELP....I've read every article I could find and apparently I either A) Arn't looking in the right place or B) what I'm reading is going over my head. I'm real new to these mods. Please answer using small word and as little alphebet soup as possible. <IMG src=smileys/smiley1.gif border="0">
Marc_03GT is offline
Old 01-27-2004, 02:13 AM
RJM02GTDrag
RJM02GTDrag's Avatar
Better hold off until you read some more opinions. First I believe the 03 has the 80mm MAF same as 02, most say that big enough for most applications. Second a 75 MM TB is prob overkill too and most will tell you it will hurt performance if you exceed 70 MM unless you add a supercharger. I would say change the intake and TB then go work on the exhaust end.
RJM02GTDrag is offline
Old 01-27-2004, 02:24 AM
Marc_03GT
Marc_03GT's Avatar
I'm planning on getting a supercharger in a month or two. But I want to put all the cheaperstuff first. I didn't know about that the 03 had an 80mm...good thing to know.Should I just put agood old 80mm K&amp;N on threre then?I REALLY want the Shaker. Should I even do the MAF?Is it possible (and even a good idea) to use the Banshee shaker with the MAF from C&amp;L (I'm still leaning towards the 85mm w/TrueFlow inlet pipe)?
Old 01-27-2004, 02:55 AM
2000GT4.6
2000GT4.6's Avatar
Is it gonna be a bitch at all to run both the shaker and the S/C? I saw an artical of the first guy (according to MM+FF) to put a blower on a mach one, and he had to get alot of custom fab stuff.
2000GT4.6 is offline
Old 01-28-2004, 01:02 AM
04ShakinSteed
I ♥ Acer
04ShakinSteed's Avatar
</P>
'03 Mustang GT has a 85mm meter.</P>
He's thinking of the 75mm throttle body because C&amp;L, through dyno testing found out that you get the most gains using a 75mm TB with their new plenum. Although they tested it with the BBK.</P>
04ShakinSteed is offline
Old 01-28-2004, 01:11 AM
04ShakinSteed
I ♥ Acer
</P>
As I told you in your earlier posts I do not believe you can do both the shaker and C&amp;L MAF. Guys, help me out with this. Is this correct???</P>
</P>
jwog666
12-27-2021 08:09 PM
JoshyGT
09-19-2017 08:52 PM
piotrek53
10-13-2015 06:54 PM
cbird1177711
09-03-2015 08:43 PM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: Banshee Shaker and MAF
