Downshift Grind
Old May 1, 2008 | 09:48 PM
jrherald420's Avatar
jrherald420
Default RE: Downshift Grind
mine grinds trying to put it in 3 sometimes. thanks ford!!![:@]
Old May 2, 2008 | 06:32 AM
Subotai_95's Avatar
Subotai_95
ORIGINAL: SlvrOhTwoGeeTee
unfortunately... no. I guess a TSB is not the same as a recall and the dealer doesnt HAVE to replace the part, and if they do they dont HAVE to do it free of charge. My dealer, is one of the ones that wont. So I will have to tolerate it until its finished then get it rebuilt. [&:]
I don't know that that would be an option brudda.. if you wait you could end up shearing all the teeth off of the gears.. There are plenty of shops around that could probably replace the synchro for you that probably won't charge you as much in labor as a dealership would. Unless your car's still under warranty, which I'm doubting since you're an 02 GT. A lot less expensive to replace a synchro than it is to replace a tranny.. [&:]
bjdutch2005
Mar 24, 2017 03:38 AM
KingRando
Oct 2, 2015 08:06 AM
guitarman376
Sep 30, 2015 05:54 PM
JDWalton
Sep 24, 2015 08:47 PM
degner122
Sep 16, 2015 07:09 AM
