MSD digital window switch
Old Mar 4, 2011 | 02:47 PM
dwtjr3's Avatar
dwtjr3
Default MSD digital window switch
Do i need a tach adapter? And how do i wire in the tach wire to the tachometer? And what are the normally open switch output, and the normally closed switch output wires? And where do they go?
Old Mar 4, 2011 | 05:56 PM
tim2002gt's Avatar
tim2002gt
You don't need a tach adapter and you don't wire it into your tachometer. I wired mine into my #8 cylinder coil pack wire. There is a common colored wire going to each coil and then there is an oddball colored wire. This is the wire you tap into for your rpm signal. Here is a post I made in another thread about window switches.
Originally Posted by tim2002gt
I have the white wire that comes from the switch tapped into the white wire w/red stripe going into the COP on the #8 cylinder. The red wire should be the common color for each COP, you want the other wire.
When the switch powers on, I have the first setting set to 1 cylinder. The yellow wire coming out of the switch connects to the negative on your solenoids and grounds the solenoids when the selected rpm is reached.
Here is the installation instructions in case you don't already have them.
http://www.msdignition.com/uploadedf...structions.pdf
Old Mar 4, 2011 | 06:25 PM
dwtjr3's Avatar
dwtjr3
Man thats great thanks man! as you could prolly tell i was clueless on how to install this. How do you like your switch?
Old Mar 4, 2011 | 08:59 PM
tim2002gt's Avatar
tim2002gt
Switch works great! I mounted mine inside my glove box so I can make adjustments easily. Plus you can watch the rpm readout to make sure its on par with your tachometer.
Old Mar 4, 2011 | 09:18 PM
dwtjr3's Avatar
dwtjr3
I am going to put mine in the glove box too. I figured that would be the best place i could put it to where it would still be hidden but visible whenever i need it. And good too know you like it, so i guess i got a good quality switch then!
cr620
Oct 3, 2022 10:18 PM
lincolnshibuya
Jul 5, 2020 03:05 AM
PaulH2
20
Jan 31, 2016 09:48 AM
firehorse02
Nov 16, 2015 11:28 AM
guitarman376
Sep 30, 2015 05:54 PM
