Poly Urethane Spring Isolators.
Old Sep 8, 2011 | 10:31 AM
cliffyk's Avatar
cliffyk
TECH SAVANT
Originally Posted by uberstang1
Hey Cliffy what is the base of that grease? I remember when I was greasing my poly control arms when I had em they said to ONLY use a sythentic "silicone" base grease, you have any insight on this? The only silicone base sythetic I was able to find is that super lube stuff, had to order from summit at the time, if I can use that green grease I rather just walk in advanced and buy it.
It actually is petro based, however it does not seem to affect urethane like the plain old lithium and other soap based greases. Prothane has their own brand of PTFE/silicone grease but it is absurdly priced last I knew...
Old Sep 8, 2011 | 10:52 AM
Jay-rod427's Avatar
Jay-rod427
Not sure what it is made of (possibly silicone based)but I usually put GM Goodwrench brand Dielectric grease on things like that and door seals that squeak. Learned this when I worked for a GM dealership. It also works really well to help slide rubber and silicon intake couplers together, in the heat of the engine bay it actually dries and kind of loosely "glues" the boots together.
Old Nov 25, 2013 | 08:44 PM
Toadster's Avatar
Toadster
would this be a good grease to use on poly isolators?
http://www.harborfreight.com/85-gram...dge-93744.html
Old Nov 25, 2013 | 11:19 PM
Toadster's Avatar
Toadster
snagged these tonight for our Eibach Pro setup...
BBK 2546 Polyurethane Rear Coil Spring Isolator for Ford Mustang $23
BBK 2545 Polyurethane Front Coil Spring Isolator for Ford Mustang $32
Old Nov 26, 2013 | 10:21 AM
dwtjr3's Avatar
dwtjr3
Mine do the same thing keith, Ill have to try the grease cliffy was talking about.
GimpyHSHS
19
Dec 19, 2023 01:12 PM
CS2007
Jun 25, 2019 09:45 PM
mungodrums
Sep 28, 2015 10:54 PM
Sep 16, 2015 07:53 PM
