Engine shuts off in gear
Old 10-31-2011, 04:24 PM
Hill x 21
Hill x 21's Avatar
Default Engine shuts off in gear
I'll apologize in advance for any mis-spellings now. I'm posting this on my cell since I don't have power (snowstorm).
I went to move my 96 gt today so my cousins could play hockey in the driveway. The car wouldn't turn over. I tried using a self jumper to no sucess. Fianlly got it jumped from my aunts Explorer. I let the car run for 15 mins then went to move it. Every time I shift into reverse the engine drops. No sound, throttle response, nothing. Anyone have an idea what's going on?
Quick info on the car: 177k miles, auto, hasn't been started since June (due to my lack of funds to keep it on the road)
I want to say its just a **** battery but don't know for sure. The battery is about six months old. Car has half a tank of gas and the voltage on the battery according to the dash is at almost 12v. Again any input is greatly appreciated!
- Hill
Hill x 21 is offline
Old 10-31-2011, 05:28 PM
cliffyk
TECH SAVANT
cliffyk's Avatar
Check the battery with a real voltmeter (multi-meter) while cranking--it is probably dropping well below the 10.5 V needed to run the PCM and then keep the generator field excited when you put the car in gear.
Better yet test it with a 100A or better yet 500A load tester, if you are lucky it just needs a good charge--if not it's toast from sitting around too long discharged...
cliffyk is offline
Old 10-31-2011, 08:51 PM
Hill x 21
Hill x 21's Avatar
At the moment I can't do much with most places closed. I know Auto Zone does free battery charging (or at least did). I might just bring it straight to the shop across town.
Old 11-01-2011, 03:59 PM
Stanglegend01
Stanglegend01's Avatar
Do you have an o/r mid-pipe? sometimes when it gets cold the engine won't turn over, and sometimes even dies upon startup because of the lack of oxygen and the computer sensing that the engine needs more fuel than it can take and that can flood the engine, causing it not to startup or turnover then die.
Stanglegend01 is offline
Granatelli Sales
01-20-2020 12:34 AM
msavoia23
12
07-07-2018 12:08 PM
5.0 kevo
09-03-2015 06:24 PM
inyadreems
08-21-2015 09:10 AM
KEM Motorworks
08-14-2015 10:13 PM
Quick Reply: Engine shuts off in gear
