Intercooler question....
Old Feb 6, 2012 | 11:04 AM
  #21
bopiela's Avatar
bopiela
WBGH Ill have pictures once mine is done. But none that are good yet - also, my test fitting isn't done. I'm getting by without an s-shaped pipe, but am ordering different couplers - mainly because I want black and secondly cuz I need an extra and a 45 degree.
Old Feb 6, 2012 | 11:16 AM
  #22
WannaBeGearHead's Avatar
WannaBeGearHead
Go Texas!!!
I have seen pictures of the piping coming from the headunit going into the intercooler. It's just the bends needed to route it up to the TB.
  #23
oxfordgt's Avatar
oxfordgt
I cut a hole for mine which made it way easier. Tuner told me he had never seen such a smooth reading from the MAF. I used a cxracing kit.
Here is what the pipe looked like
Old Feb 6, 2012 | 11:56 AM
  #24
crash's Avatar
crash
BrandofPoop
^That looks clean! Btw, did you finish another tour? How long are you back?
Old Feb 6, 2012 | 12:18 PM
  #25
WannaBeGearHead
Go Texas!!!
That gives me a better idea of what I need to do for the piping. I don't know if I'd cut a hole like you did. I'm guessing I'd just need a few 90* elbows. To get it through there. I like the little piece you had welded up to fit into the TB.
Anyone else have pictures of their CXRacing kit?
Old Feb 6, 2012 | 06:49 PM
  #26
oxfordgt's Avatar
oxfordgt
Well I got back from Afghanistan last Feb.
Built this and sold it before I left in Sept for Korea
Now I'm about to head back to TN next week.
Old Feb 6, 2012 | 08:09 PM
  #27
dwtjr3's Avatar
dwtjr3
Ox- with that bumper support how did you mount your IC? And have any links to those supports?
Old Feb 6, 2012 | 08:21 PM
  #28
oxfordgt's Avatar
oxfordgt
2 L brackets up top attached to the header panel and 2 L brackest on the bottom attached to the radiator support.
With a procharger kit I just used the brackets that came with it and mounted it as per the instructions.
PM me if you want a support. My buddy and I make and sell them.
Old Feb 6, 2012 | 11:02 PM
  #29
WannaBeGearHead
Go Texas!!!
Ox, I found someone else who cut a hole like you did. It actually looks like a great idea. I like how you get a good straight flow going into the MAF. I'm think I'm going to do that same setup. That will give me the best MAF readings. Just have to make sure my air filter doesn't get in the way.
Also, you said you bought the CXRacing kit. Did it come with all the tubing needed to run it the way you did?
Old Feb 7, 2012 | 12:19 AM
  #30
WannaBeGearHead
Go Texas!!!
Originally Posted by oxfordgt
In this picture is that (2) 45* 1ft bends, (2) 90* 1 ft bends?
