Reviving the Project
Old Oct 17, 2013 | 11:34 AM
dwtjr3's Avatar
dwtjr3
Yeah this site has died a lot from what it was.
But I have never ran the strange setup, but I think uberstang does and he is pleased with it.
Old Oct 18, 2013 | 12:10 PM
uberstang1's Avatar
uberstang1
Chupacabra
I run strange 10 ways all around, couldn't be any more happier for a street/strip car. The rest of my suspension setup consists of a Qa1 tubular k member, upr tubular front a arms, upr coil overs up front with 175lb eibach springs, steeda bumpsteer, energy suspension poly motor mounts, custom sub frame connectors, reinforced torque boxes, stock rear springs with 1/2 coil cut and poly isos, team z relocated spherical upper control arms, team z spherical lower control arms, AJE crossmember with solid mount plate and poly bushings at frame location. If you don't like NVH stay away from spherical control arms.
Old Oct 20, 2013 | 11:19 AM
vertmustang98gt's Avatar
vertmustang98gt
My suspension woes should be solved then. I have everything listed above expect upper and lower control arms. Thanks for the help.
I'm just worried about the PI swap on my car since my fuel rail is different than the 96-97. I'll have to figure it out myself I guess. I can drive the Fusion, in any event. No worries, thanks for the help.
Old Apr 14, 2014 | 07:10 PM
vertmustang98gt
I ordered Koni Yellow struts today, I hope they work with the Granatelli's!
Jan 21, 2016 01:30 PM
Matt's 95 Stang
Oct 5, 2015 07:16 AM
Jack Weinmann
Sep 25, 2015 03:59 PM
ThatJuanStang
Sep 25, 2015 08:01 AM
stealth_GT
The Racers Bench
Sep 22, 2015 02:19 PM
