Pvc help
Need help with pvc issue. I have an 03 gt and had a leak from valve covers. I decided to get another pair as mine had a piece of lip missing towards back. Go to the local junk yard and got a pair. When I went to install pvc valve off old valve covers the Pvc valve on passenger side is the same. The pvc that goes from the intake tube to driver valve cover did not fit my new junk yard valve cover. I found out the donor valve covers were off a 99. I have not been able to find a pvc piece that fits in the driver side valve cover. I've bought generic Ford ones but no go and one they pull up on computer has two hose hookups which is not what I need. Does anyone know the part number for a pvc connector that would work? Or the size or a similar pvc off another Ford that would work? The pvc was not on the junk yard car and they have no other gts 99 or older. I grabbed one off a Lincoln and it fit sorta but not snug.
The PCV is single output, there is a "Y" piece that connects to the part. I don't think
the PCV itself has the "Y" on it, but if it does, you will have to plug one of them up.
There are so many versions of that twist in style valve. They're all 6A666, but preceded with:
2L3Z, and so many in that format.
Then there are the push in ones:
This is also 6A666, different prefix...
https://www.ebay.com/itm/PCV-Valve-M...8/262274109345
Also, it is PCV not PVC, you made that mistake EIGHT times....
You're gonna have to search for it. If you get one locally that has two hose hookups, cap one...
02mgstang
Nov 25, 2009 09:41 AM
