Rotor rubbing against caliper bracket HELP!
Old 07-16-2018, 06:22 PM
01MUSTANGBULLITT
01MUSTANGBULLITT's Avatar
Default Rotor rubbing against caliper bracket HELP!
Hey guys so im at a loss on my 2001 gt bullitt, just put all new brakes and calipers on it off of summit, SPECIFICALLY fitted for the mustang bullitt because my caliper bracket was rubbing on rotor, STILL THE SAME PROBLEM, i can physically see where its rubbing too and its on the drivers rear, only possible thing i can come up with is that the axle is bent or the bearing has play? Any help or advice please and thank you!
01MUSTANGBULLITT is offline
Old 07-16-2018, 06:23 PM
01MUSTANGBULLITT
It only makes noise/rubs too when i go left even slightly, if im making a right u cant hear it at all
Old 07-16-2018, 06:46 PM
08'MustangDude
Banned
08'MustangDude's Avatar
If the rotor side facing you is hitting the bracket, then the LH axle
is moving outward on right hand turns, or bearing to the right. This is
usually in the differential.
Put the back end up on blocks, and see if you can pull and push the
rear wheel in and out on that side.
A temp fix could mean the use of a washer between the bracket and the
mounting surface. Sandwiched between the bracket and mount.
08'MustangDude is offline
Old 07-16-2018, 07:09 PM
01MUSTANGBULLITT
Its on the outside facing me, ill check it tm and see whats up, what i dont understand is if there is play in the bearing why would it only be when i make left turns that it rubs?
Old 07-22-2018, 05:38 PM
WJL
WJL's Avatar
8.8 rear ends have "C" clips and have very little to no axle end play, however shimming the caliper bracket could resolve your issue
how many miles do you have on the car?
WJL is offline
Old 10-26-2023, 03:26 PM
Attitudeguy
Attitudeguy's Avatar
I have the same issue however I have a ‘00 GT that I swapped a 2003 Mach 1 rear end into. Axle came with Mach 1 caliper brackets so I upgraded to the bigger Mach 1/Bullit Rotors and Mach 1 caliper bracket. Similar issue with the outer of the bracket contacting the rotor so I shimmed the top and bottom of the bracket. Any fix to your issue? My car likes to eat brake pad clips and am wondering if this is my issue. Thanks.
Attitudeguy is offline
itscalledred
12-04-2012 11:29 AM
EaZy DuZ iT
04-27-2010 11:39 AM
99GTKevin
05-03-2008 12:49 PM
jaztherot
10-12-2007 01:05 PM
SidGT
07-29-2007 11:06 AM
Quick Reply: Rotor rubbing against caliper bracket HELP!
