Quick driveshaft question please help.....
Allright I have a quick question....
I have some Roush rear springs installed on my car. They lower the rear end to an almost level position. The instructions said approximate 1" lower. I want to install a PSI Performance 4" aluminum one-piece driveshaft on my car that a buddy of mine has installed on his car currently. He is going to the H&R Supersport springs, and he knows he will not be able to use the driveshaft while going that low. The question is... will I still be able to use the aluminum driveshaftwith my Roush springs if I were to buy it from him?
Yea you can use it but you will need either adjustable Lower control arms and/or Upper control arm. You need these because you will need to adjust the pinion angle which will be off from lowering + 1 peice ds
the 1" drop is fine for a 4"ds unless you drive with 4 200 pound people in your car. adjusting the pinion angle ensures you are getting the most out of your power but is not necessary right away.
Luke9222
Oct 22, 2015 11:55 PM
