S/C or Turbo
S/C or Turbo
X-Wife will be paid off in a few months, so I will have some extra cash burning a hole in the pocket, should I go with the S/C or the Squires Turbo system. Looking for some pros and cons of these two systems
RE: S/C or Turbo
This is a no brainer, The TURBO! I personally with go with brenspeeds Hellion kit, the pros of a turbo that it doesnt loose power through the circumstential drag due to the motor, thus creating boost fast resulting in a quicker street machine, consequently you will have people debate and speak of turbo lag which in some cases is true but when dealing with this application the turbo lag is nonexistant. Superchargers are great but there a dime a dozen everyones got them, turbos do create much more heat inder the hood take that into consideration before making your decision.........if I where to go with a S/C it would most likely be the procharger, its a self contained setup that makes boost at high rpm, thus if your not in the throttle all the time the load on your motor wont be as great unlike a KB that makes full boost at low rpm.
RE: S/C or Turbo
They dont give you any boost until you go wide open throttle - so NO LOAD unleass you have your foot in to it.
Turbo is hard to tune over 15 PSI- runs hot under the hood. Turbos fail quire often too.
