JBA vs. BBK?
Old Feb 15, 2008 | 04:39 PM
  #21
OrangeGTCS's Avatar
OrangeGTCS
Default RE: JBA vs. BBK?
The ratcheting wrenches would be perfect. Yes, when I lifted the motor, I placed a 2x4 between the jack and the oil pan.
ORIGINAL: bkmagby
Thanks for info guys.
OrangeGTCS, do you think a set of ratcheting box end wrenches would help were the open end wrenches are needed? Also, how did you go about jacking up the engine to remove the motor mounts? Did you place something like a 2x2 under the side rail of the oil pan and just lift the side of the motor enough to remove the motor mount?
Thanks again.
Old Feb 16, 2008 | 02:47 AM
  #22
Simon1's Avatar
Simon1
ORIGINAL: OrangeGTCS
ORIGINAL: bkmagby
Thanks again.
It's actually rather easy. Ounce the mounts are unbolted from the motor and the mounts are loosened from the cross member, I used the biggest screwdriver I had and popped the mounts out.
Old Feb 21, 2008 | 01:39 AM
  #23
ndgoalie35's Avatar
ndgoalie35
JBA's w/ SLP's FTW!
Jb145700
Aug 21, 2022 06:37 AM
Luke9222
Oct 22, 2015 11:55 PM
12bigredstang
Sep 24, 2015 05:46 PM
JT76
Sep 20, 2015 11:32 AM
