A few questions for the pros
I am just wondering what I should do in reference to my next modifications. I am not afraid to admit that I am addicted to adding modifications to my baby. But first I have some questions:
1. How many millimeters is the stock throttle body on my '06 Stang?
2. Is it a modification thats worth the money?
After looking at the mods that have been done, what would you do next?
If you're asking if an aftermarket throttle body is a worthwhile investment, I think you'll find the common consensus is a resounding no, unless you're running a high boost application.
If you are running a high boost application, and your throttle body is now the restrictive portion of the system, the GT500 throttle body is (I believe) the commonly preferred part of choice.
Its called the black diamond TB- single blade and 1600+ cfm
I did the math on it one day, and to flow enough air in NA form to have the stock TB be a restriction, you would have to port the heads and be displacing nearly 6 liters.
But to answer the question... the stocker is a twin 52mm opening.
Luke9222
10-22-2015 11:55 PM
treesloth
09-28-2015 07:03 AM
