Violent screetch coming from pulleys. Help!
Old 01-12-2009, 06:44 AM
clearym
clearym's Avatar
Default Violent screetch coming from pulleys. Help!
The middle of last week I heard a small sweak coming from the engine compartment and determined that it was coming from the accessory pulleys. I waited until the weekend to have a thorough look at it and in a couple of days it got a lot worse. I checked all the pulleys to see if they were loose or wobbly and they weren't. Just using my bear ear narrowed it down the pulleys in the center (crank, water pump and maybe the alternator). I sprayed some AeroKroil (high quality penetrant/lubricant) on each of the centers and shafts (as close as I could aim) of the pulleys both when the car was off and when it was running. The problem has not gone away. It sounds like when car used to have the belt slip on acceleration accept it does it all the time. The sound changes with RPM and amount of torque applied but, its always there and very high pitched, violent and annoying.
Any help would be appreciated.
2 years ago I put in the Steeda Pulley kit but, have not had a problem since.
clearym is offline
Old 01-12-2009, 07:04 AM
Nuke
Nuke's Avatar
I've yet to put a wrench to anything on the belt line in this car but it sounds like the belt tension has loosened up. I'm sure there's a way to tighten it and, if that's it, it's a pretty quick fix. If you're not up to the task, you should drop by any decent shop.
Nuke is offline
Old 01-12-2009, 11:53 AM
ski
ski's Avatar
If the stock idler pulley is still installed, then it may be the cause.
https://mustangforums.com/forum/5769475-post17.html
ski is offline
Old 01-12-2009, 02:57 PM
d_ames117
d_ames117's Avatar
If the tension is good, it's possible that the rubber in the crank pulley has deteriorated allowing the outer metal band to spin which causes a squeak (if the crank pulleys are of this design). Happened on my Saab - squeaked at startup and during acceleration.
Dustin
d_ames117 is offline
Old 01-12-2009, 05:43 PM
aclass
aclass's Avatar
If it's constant then it sounds like you've lost a bearing in one of the pulleys. Easiest place to look first would be the idler and alternator. If it's that bad then it should be obvious.
Good luck
aclass is offline
Old 01-12-2009, 06:42 PM
charliebrown266
charliebrown266's Avatar
Try taking the belt off and spinning the pullys by hand to see if you can hear.
charliebrown266 is offline
Old 01-13-2009, 03:43 AM
Simon1
Simon1's Avatar
That's what i would do.
Simon1 is offline
bjdutch2005
03-24-2017 03:38 AM
zsmart
Convertible Tech
02-29-2016 08:33 AM
uedlose
09-10-2015 03:30 PM
zanemoseley
09-06-2015 12:58 PM
tmdm
09-04-2015 06:45 PM
Quick Reply: Violent screetch coming from pulleys. Help!
