Help! Rear/Transmission Issue
Old 06-09-2010, 08:53 AM
JRANGER
JRANGER's Avatar
Default Help! Rear/Transmission Issue
Ok so i have had this 05 Mustang GT for almost a month now and I just noticed this weird vibration occurring only when im @ 40 - 42 mph. The car starts vibrating from the passenger side and even makes a little noise. It kinda is like going over the warning strips on the side of the interstate but not as loud and only at around 40mph. I only noticed this because i got stuck going 40 in traffic one day and i started feeling the vibration and hearing the noise. ANy ideas? I know this could be just a bent rim or needing balancing but it could be otherwise?
Anyone had this issue? Any TSB?
JRANGER is offline
Old 06-10-2010, 11:30 AM
JRANGER
JRANGER's Avatar
Anyone???
JRANGER is offline
Old 06-10-2010, 12:04 PM
hammeron
hammeron's Avatar
well like you said it could be wheel related and it might
also be something in the driveline.
hammeron is offline
Old 06-10-2010, 01:11 PM
JRANGER
JRANGER's Avatar
What do you mean driveline? Would that be covered under warranty?
JRANGER is offline
Old 06-10-2010, 04:08 PM
hammeron
hammeron's Avatar
well in this case i'm thinking it might be drive shaft or
maybe the pinion angle. i don't know if you have the
stock drive shaft or an aftermarket unit, so it's hard
to say exactly what's happening on your car.
hammeron is offline
Old 06-10-2010, 05:10 PM
ShaneM
ShaneM's Avatar
Unless you have an extended warranty, that car is long past its factory one is it not? Any aftermarket wheels put on recently?
ShaneM is offline
Old 06-10-2010, 05:13 PM
03gt04mach1
03gt04mach1's Avatar
Might be the outer Axle Bearing is going out.
03gt04mach1 is offline
Old 06-17-2010, 10:40 AM
JRANGER
JRANGER's Avatar
Ok, so i had about 400 miles left on the warranty the dealer gave me when i bought the car (2k warranty) and i took it in yesterday...After 6 hours they found the issue! I need new transmission mounts. They are double checking everything and trying to order the part via warranty
JRANGER is offline
Old 06-18-2010, 09:23 AM
03gt04mach1
Well, I was way off. At least they're checking everything under warranty. It's strange a mount could could go that quickly in a newer car.
cr620
10-03-2022 10:18 PM
lincolnshibuya
12-08-2015 04:37 PM
Thunderball
15
11-22-2015 11:49 PM
chrisdbassplayer
10-13-2015 06:53 PM
Bokeo
10-10-2015 08:28 PM
Quick Reply: Help! Rear/Transmission Issue
