How much power can a stock gt hold?
#22
I don't see how parasitic loss really has anything to do with the durability of the motor. Parasitic loss is a subtracting factor from the total power made by the engine meaning it occurs AFTER the power is being put out. An engine making 500hp, but losing 50hp to parasitic loss is still being utilized as if it was making 500hp. So it's seeing 500hp worth of stress, not 450.
#23
I've been at 474whp on Kenne Bell's stock tune for over 5,000 miles now on my stock motor. still going strong! at some point I'm going to add water/meth injection and go up in boost just enough to hit 500whp then I'll call it a day until I build the motor
#24
whats your total timing full load?
#25
#26
as to shift point... you shift just past the peak power that way you fall back into a fatter part of your power band. if you shift to early the motor will fall out of that band
#27
The crank has to turn the flywheel on one end (or torque converter), and the pully on the other end. If you have a supercharger that takes 60hp to turn (at 6500 rpm), that is 60 less hp you see on the other side of the crank as well (at the flywheel or torque converter). Now the power travels down the trans, which has rotating mass that takes power to speed up or slow down as well as friction. Then to the driveline, which is the same situation - mass to turn and friction. Then the rear end, same story as driveline and trans. Then to the wheels where you have mass to turn also. So if you measure at the wheels, you are going from the power at the cylinder, to the rods, to the crank, and then you have to start subtracting the "parasitic" losses of the alternator, water pump, power steering pump, A/C, supercharger, transmission, driveshaft, rear end, and wheels.
A turbo has no parasitic power consumption as nothing from the crank drives it. It can produce some small amount of power loss due to restriction in the exhaust, which affects the ability to fit more fuel/air mixture in the cylinder chamber, and causes some minor power loss. Everything else is belt driven and takes power to turn. A typical straight lobe roots supercharger will take 50-60 hp to turn to make 9 psi of boost. A typical twin screw or centrifugal will take 25-35 hp to make the same amount of boost.
Regardless of which type you go with, the stress on the block, cylinders, rods, and crank are all the same, but your power at the wheels can vary by as much as 60 hp! Furthermore, with a lighter flywheel, lighter driveshaft, and lighter wheels you can free up even more rwhp without changing the amount of stress on the crank.
This is why you can have anywhere from 420-500 rwhp at 9 psi and still be "safe". In all cases, 9psi is putting the same strain on the rods.
However, having 100% traction when putting that power to the ground can cause an extreme amount of stress on the rods and crank, and even with 9 psi you can have a failure. If you build up the inertia in all the spinning and moving parts then suddenly put a load on them and you can generate many times the normal force they normally transfer. This is why drag racing is dangerous to your engine under any circumstances.
#28
i def believe that. 05 saleen, when they first had maguson superchargers, the intercooler was leaking, after the car had burned through all the coolant, it would put the cooling system for the intercooler under vaccum. this car dyno'd 200ish rwhp. i mean 200-210 that low. where as stock its been 269-275 average.
#29
rotating assembly & block will hold 500hp-550hp with the right tune & set up....I was making a little over 500 with the bottle(150 shot) & ABUSED THE HELL OUT OF MY CAR!!!! D'aGASTINO tuned my ride. Was a guy named Scott Beers I believe.
yourmom6990
3.7L V6 Technical Discussions
10-14-2015 10:08 PM
musnicki
09-23-2015 07:11 AM
