Putting the power to the road
Our control arms are tig welded right here in South Florida using American chrome-moly and custom designed Energy Suspension polyurethane bushings, and they have a lifetime guarantee!
and as for the "build" of the car... I want a power house, a straight up race car, I see too many people putting mini turbos in civics around here, driving around with primer on their body kits and wings the size of my entire trunk cover - that's not a car, it's a joke. I want my Mustang built to the fullest potential, a real street monster. something I can cruise around in around town with my girlfriend and when some ricer comes up, the idle roar of my engine will be enough to make them back off or feel the wrath of a fully built pony ;-)
That's right!!
No problem. I'm happy to help, anytime!
Obviously, "real street monster" is subjective... but at UPR Products, our 3V GT demo vehicle could be considered a Dr. Jekyll & Mr. Hyde monster. If you drive it around and keep your foot out of the throttle, it's a nice tame street car that can be driven cross-country with the A/C on and the music blasting. But when you drop the hammer, it runs 10.17 @ 140 on street tires!! Basically, it's a JDM shortblock, Roush blower, UPR Products suspension, and sticky tires. A low 10 second car is usually more than enough to destroy the Fast and the Furious from light-to-light. If that's what you're looking for, we can help you get there. (and even faster if you'd like!)
That's right!!
what kind of transmission do you guys run exclusively? built autos or manuals?
You just described my dream car! lol.. I want to be trapping 146+ though
I just set up my reat with Steeda Billet LCA's, UPR LCA Relocation Brackets, UPR Adj UCA and Bracket, Adj Panhard, H&R Race springs and Tokica Adjustables.
I have the LCA's at a perfect 0 degrees. Pinion angle at 1.8 with the 1 piece driveshaft. No wheel hop ever now. No more lag or slop from tranny to rear. I hit the gas low rpms rolling in gear, no bang!
The tokicos are set middle, a little stiiffer on the right side, 1/2 turn.
The car def puts more rubber to the ground straight line and cornering now.
Thats the best I am going to get this car. Never gonna run slicks...
I've looked a little more into upper and lower control arms and I've been that they cushion your suspension system? am I reading this right? does that mean they they literally control things like your sway bars or something? a little insight would be apperciated before I drop $350 into U/Lca's and a panhard bar ;-) (btw I'm starting to lean towards a full suspension upgrade minus the shocks... already have those in!
http://www.youtube.com/user/sraldiris#p/u/5/iYa0LnbjTyc
Here's a pic:
This one has the factory 5r55 automatic, but we use autos and manuals in our cars. Also, we recently installed an IW 15% overdriven crank pulley and the car picked up over 40hp. We'll be shooting for better ETs & MPH.
The factory control arms work poorly for two reasons. Their bushings are way too soft, so they have a lot of flex, making the suspension movement sloppy and unpredictable. They're also made of stamped steel, which is also prone to flexing, and general nastiness. Our control arms eliminate the slop in the suspension, letting it work as it should.
Here is the rear suspension on our 10-second 3V GT:
If you want to put the power to the ground, here's the setup I'd recommend for you (the only difference between this and my track setup is the tire recommendation):
15x8" rear wheels with 275/50/15 drag slicks of your choice (I like M/T and Hoosier)
15x3.75" front wheels with 26" tall skinny tire of your choice (I run M/T)
QA1 Single adjustable rear shocks (set 5 clicks from full firm)
Strange adjustable front struts (set full loose)
UPR rod end LCAs (I set mine to factory length)
Eibach Drag springs w/ drag bag (12psi)
I have many, MANY more mods than this, but these are the mods that best helped me plant the power to the ground.
If I may add to UPRSharad's discussion of J&M LCA's...
I ordered the poly-ball ones from AM and they clunked tremendously when I first put them in. Every bump and throttle adjustment would pull a clunk out of the rear end...
It's been 3 months now and the clunking is completely gone.
My guess is they just had to be worn in maybe?
Now that problem has disapeared, I can say that LCA's do make a big difference in keeping the rear end in line and stop heel hop.
