Need to decrease boost/HP
Old Feb 19, 2012 | 01:56 PM
Simon1's Avatar
Simon1
ANd yeah, the 60# injectors will be just fine. Anything else done to the fuel system?
Old Feb 19, 2012 | 05:05 PM
sschevy396's Avatar
sschevy396
It has dual gt500 pumps , Mafia lightning extender, Mafia 90mm lightning meter also has stage 2 cams in it , will the cams be ok with reducing boost? and has a 10% overdriven balancer, I don't know if that will affect it also? sorry for all the questions, I am going from a 69 chevelle big block to this , so its is somewhat of a learning curve...but I am much happier now...driveablity is nite and day...Thanks again for all the help.
Old Feb 19, 2012 | 11:46 PM
Simon1's Avatar
Simon1
So everything you have will be fine. Which stage 2 cams and are they on a lock out or on a limiter? After market cams and FI should also have a limiter within the VCT system. Just ask whoever installed them.
Some shops do it and customers don't even know it.
The over drive crank pulley will give you more boost. I beleive the GT500 pumps are only good to around 550 rwhp. If you have a dual BAP you will be good to the high 600s I beleive. Would have to look around to see the real answer.
Most importantly, find a tuner that really knows what they are doing. Ask for references or ask here. We are here to help.
djbigskrilla
Sep 20, 2022 01:04 AM
ak98
Sep 10, 2015 10:33 PM
kawiguy827
Sep 1, 2015 07:09 PM
mustang7171
Jun 5, 2005 06:41 PM
Mustang Novice
Mar 5, 2005 08:44 PM
