4 Cylinder NA and Turbo This section is for questions pertaining to stock or modified 4 cylinders, including the performance 2.3L applications
How Does a A4LD work?
Old 03-04-2012, 09:20 AM
ches
ches's Avatar
Default How Does a A4LD work?
Any body got A link to how the A4LD works, Having troubles with OD, I under Stand that 3-4 And the TCC is Controlled buy the EEC but want to get more details? I tried Google but found nothing helpful?
ches is offline
Old 03-14-2012, 12:48 AM
ches
ches's Avatar
Been driving in Drive, not Over Drive but still having a terrible vibration when I stop from high speed as the trans down shifts, ones it shifts back down vibration goes away.
ches is offline
Old 03-20-2012, 11:28 AM
ches
ches's Avatar
Think my torque converter went out, thinking I might do the T5 swap!
ches is offline
Old 04-08-2012, 08:03 AM
mg man 75
mg man 75's Avatar
This may help. I am not much help on automatic or 5-speed. Maurice
http://www.therangerstation.com/tech...4LD_manual.pdf
mg man 75 is offline
Old 04-08-2012, 08:29 AM
03gt04mach1
03gt04mach1's Avatar
I'll bet if you drop the Pan, you'll find metal shavings in it. The A4LD is a small and light duty trans. They sure weren't built to last, especially if you went even a little beyond light duty use. Definitely, go for the stick swap.
03gt04mach1 is offline
Old 04-08-2012, 06:31 PM
mg man 75
mg man 75's Avatar
A A4LD can be made heavier duty. Never done it just read it.
http://www.explorerforum.com/forums/...d.php?t=146953
There is another guy modifed and ran 2 computers to run the heavier duty one.
http://www.explorerforum.com/forums/...d.php?t=308447
Now you may say why. Turbo and automatics work good together don't loose boost between shifts and if get up large amount of HP the 2.3 clutch won't hold up. Some have went to 5.0 pattern to get bigger clutch surface.
The other option is c-4 takes a rare bellhousing or 5.0 adapter and custom torque convertor
Me I run a c-4 [rare bellhousing] only 3 speeds not the greatest for daily driver and gas mileage. Mostly wife drives it local so no big deal to me.
Gearvendor overdrive is available for c-4 but pricey.
Now a person on turboford is working on a controller for the later trans to control the 5r55e or so trans. Maurice
Old 04-09-2012, 07:15 AM
ches
ches's Avatar
trans is "ok" other than the down shifting, have been chancing a no spark problem for a few days now?
ches is offline
1TUFF302
11-05-2015 04:02 PM
Pyrate Dave
09-10-2015 07:30 PM
96stang3.8
09-10-2015 06:42 AM
JoshyGT
09-07-2015 02:04 PM
cbird1177711
09-03-2015 08:43 PM
Quick Reply: How Does a A4LD work?
